i dont' see why not as long as the injector is getting the voltage it needs, make sure you use the same gauge... and I would do them one at the time so you don't get them mixed up
thanks guys. what a nightmare had to yank my engine and cut and lengthen my harness just to mount my new intake manifold. but it will be worth it in the end i.
I lengthened the complete engine harness yesterday, what a pain in the a--. But it's done I soldered all the connections except the injector wires. Since they were larger they would not solder as neat so I found these solder/heat shrink splices. You just heat them and they do everything in one step, hopefully they hold up. As far as wiring, I had a old truck harness so I matched the majority of the wires with the same gauge and color and the injector wires I did in the same gauge used by the factory. I sure hope it is all good????!!!
