Injector return lines
Cougar281
1,809
253
St Louis, MO
Is it possible to repair/replace one section of the return line? When I leveled the motor, some fuel that was still in the line started leaking from somewhere around the end plugged into the #8 injector (the return line that got knocked out). I'm not sure where it was coming from, but I don't think it was coming from the injector as the "hose" was wet about 1/2" to 3/4" up from the injector.
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
Check the plastic "T" fittings at the top of the injector, they crack or break. Last i heard it's still a dealer part... and you have to purchase the entire side (4) not just the "T". I couldn't figure out a way to repair the plastic, sorry.
Cougar281
1,809
253
St Louis, MO
That's what I'm thinking may be broken... I'll look closer later.
