Injector return line leak
Robby05
Jul 25, 2014
498
Spokane, WA
Opened up a friend's LB7 today because of a suspected return line leak on the pass side. Once I removed the valve covers I pressurized the return side with 15 psi to verify the leak and sure enough, all were leaking.
The one question I have is 2 of the injectors started leaking on the inlet side while the return was pressurized. Are those 2 that leaked air out of the inlet bad?
