It's to ready and copy Injector Flow Rates from ECM to GPCM or vise versa. You can't input actual numbers like with a tech 2.
It comes in handy when replacing ecm's in LMM's.
Then what's the program function for? Also how would I read the flow rates?
Sent from my PC36100 using Tapatalk
I have nothing to add but man clean your V2.
Sent from my iPhone 4S
So if I find someone with good balance rates on matched injector I could copy his and load it on mine
I wouldn't. I would put the flow rates number/code that is on the injectors in your truck. Not someone elses.
I tried putting different flow rates in mine to see if it would cure the balance rate issues I have too but it didn't make a difference. But I also have LMM injectors in my LBZ so can't say if it was a valid test. Whenever I input the flow rates off the LMM injectors I have into the tech 2 it would say invalid but it would still take the number and allow it to be programmed into the ecm.
