injector problem?
S Phinney
4,008
Quncy, Fl
I have a very unusual problem. Intermittently, my engine is noisy and sounds like a fuel related issue. It is worse when the fuel and air temp is hotter. It sounds like a knock but when you touch the gas it is gone. Sometimes the idle is rougher than it should be. Give me your opinions.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
have you checked balance rates while it is acting up ?
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
could be the fca, injector rattle would rattle anytime when cruising with your foot on the throttle and would go away when you let off the throttle.
the fca would start to make noise when there is no throttle being applied
S Phinney
4,008
Quncy, Fl
Balance rates are bad off on two injectors. Six injectors are in the -2.0 area and one is +5.5 and the other +7.17 areas respectively. The noise occurs more often when fuel and air is hotter. It will also smoke white/blue when enhine is cold. When heat get into the motor the smoke vlears up. These are 40 over,extride honed, injector nozzles that are flowed and balanced. They have 6800 miles on them.
TrentNell
Jul 7, 2008
7,543
slc tuah
i cant think of anything besides injectors or mechanical problem to cause the balance rates to be that far off . i know the built motor was just finished wasnt it ?
S Phinney
4,008
Quncy, Fl
Yes it has 6800 miles on it. Everything was new other than crank and pistons. I had the pistons cut and coated. Everything went together very well. When it was first logged the rates were exceptional and the motor was unbeleivably smooth.
