HELP NEEDED
Ok guys need some help here, placed the truck up for sale and I guess she got upset with me. I pulled it off the market until I sort this out. Last night on the way home I had an injector misfire when passing someone. Then it happened at lower and lower rpms. Eventually it got to the point I had to limp it the rest of the way. Threw code p0301, injector misfire on #1. Had this issue a little while back and found a shorted wire. Searched the harness over and found nothing. I ice picked the connector thinking maybe that's the issue. Took it for a spin a second ago and it's worse with codes p0300 injector misfire detected, p0301 injector misfire on 1, p0302 misfire on 2. Any help in which direction would be greatly appreciated.
06 lbz, 100% overs, dual stock lbz pumps, Danville tunes,
Symptoms are crappie idle, fuel knock, no smoke or haze and the obvious misfire. Maybe crank or cam position sensor? I was thinking injector failure but now it's moved to another injector I am thinking electrical issue. Ohh and replaced the o ring and gasket and hold down bolt on the #3 injector, symptoms started the following day.
