Injector Knock???
guytonLBZ
Apr 15, 2010
so long story short. trucks been down for a few months while i put compounds on it and when i finally started it up i started to get a REAL BAD knock coming from either cylinder #5 or #7. hooked the V2 to it and the only codes i got out of it was
P0098 Intake Air Temp Sensor 2 Circ High
P0090 Fuel Pres Reg Ctrl Circ
P0088 Fuel Rail/Sys Pres-Too Hi
P0673 Glow plug #3 Circ failure(i just changed this glow plug:confused:)
when it starts it smokes heavy like a injector is hung open. ive looked at all the connections and everything looks fine. i havnt checked the balance rates as of yet(scared to let the truck run that long makin that god awful noise). im just curious to if im missing something or not.
im decently well rounded with my truck im open to anything if anybodys got any ideas of something that im over looking.
Thanks in advance
guytonLBZ
Apr 15, 2010
Not to sure at this point. i havnt put my laptop to the truck yet but the P0088 code make it sound too good.
tinman22
715
Stillwater NJ
sounds to me like your fuel pressure regulator is either not plugged in or broken connection some where or its stuck. i'd bet if you put the lap top on it the rail pressure is 20k or better at idle.
just a guess from where i'm standing
guytonLBZ
Apr 15, 2010
broke connector on the FPR...pressure was WAY above 20K...good call dude:thumb: now i jus have to hope this is my only issue:D
guytonLBZ
Apr 15, 2010
i may not post here much but i do read a lot here. plenty of good info when it comes to the "go faster" side of things
guytonLBZ
Apr 15, 2010
sweet. glad you found that issue. now fix it! lol
new one will be here today and will go in tonight along with my Hellman Sump:D
but heres what caused it...look about right? can we call this the culprit? lol
