I have a 05 Kodiak that I have been working on and off for quite some time. It lost the #1 piston over a year ago. I looked at the truck and it had a balance rate of +15 on #1. I did a compression and sure enough it was zero on #1. The owner had a buddy pull the motor and rebuild it. Well the buddy didnt know what he was doing and caused alot more issues. I looked at the truck again to see what was going on it had a terrible rod knock. I had to completely rebuild the motor. Before the motor came out I checked the balance rates and cylinder #1 had a +15 balance rate again. After I tore the motor down I never found anything that would cause the high balance rate on #1. The owner replaced the #1 injector and put the motor back in the truck. I helped him get it running the other night and everything is fine but cylinder #1 still has a +15 balance rate. I swapped #1 and #7 injector and the high rate did not follow the injector.
So I know there is nothing wrong internally in the motor to cause the ECM to think #1 is low on power. I know the injector is not faulty. I am starting to think the FICM is bad.
What does the ECM look at to calculate balance rates? I am assuming it the acceleration of the crank/cam reluctor wheels when each injector is fired?
