Injector cups
Darin13
Oct 6, 2009
68
NY
Ok so I picked up my heads from the machine shop today and I didnt remove the injector cups before hand so when he decked the head he says he ran a chamfering tool over the edge of the cups is this ok?
S Phinney
4,008
Quncy, Fl
The cups need to come out and reseal using new o rings. Make sure to use the proper sealant on the cups. I always use the GM red made for this and have had zero problems with it sealing.
Darin13
Oct 6, 2009
68
NY
How do you get them out and is it a problem if he removed material from the end of them or is it more important that they are properly resealed
S Phinney
4,008
Quncy, Fl
Any removed from the end shouldn't be a problem but he had to take a lot off to get there. Normal clean up only takes around 6-8 thousands. You should have also had the intake side of the heads machines as much as the bottom to keep proper alignment of the y bridge.
Sent from my SCH-I500 using Tapatalk
