Injector Balance Rate
Mikey
Drag Racer
Jun 13, 2009
560
3
Been a little over a month with the new injectors.
#8 has a value of about 8.0 and the average slowly rises from the 2.74 shown in the picture to over 6.0 (Seems wrong? as the others are closer to 2)
What is max acceptable balance value?
What could be the cause of the high numbers?
Could it be a leaky seal or a maybe a mechanical failure in the injector?Warranty?
Also #4 injector shows -4.0. Is that ok?
Thanks for all the help!
stumpman750
Feb 20, 2012
40
Arnt they supposed to be at +/- 4.0, seems something isn't right, seal, loose fitting, wire connection?
stumpman750
Feb 20, 2012
40
Mikey
Drag Racer
Jun 13, 2009
560
3
Exergy did the work.
I hear what I assume is injector rattle at about 2000 rpm.
Sounds like a rod knock but hopefully it isn't because it runs smoothly until then.
Pretty sure it is the injector as the balance rates point to that.
