So after The motor build I had a fuel leak after 3 miles. I found out where it was coming from. Blew up the CP3. Had metal all in the valley and the 2 freeze plug things had dents all in them and were laying in the valley. I put it back together and truck runs decent. Idle is a little rough sometimes. Checked the balance rates and I have 3 bad from 7.0-10.0 Same injectors that came out but with different nozzles. One of the injector balance rates doesn't fluctuate. It stays at 7 even when you go into drive or crank up the rail pressure. Anybody seen this before? Logged a run at 2100us and only held 19k psi. Im guesssing I probably have shit in the injectors from the blown up pump but why would that one not fluctuate?
