I tuned a few LB7s for a few of my friends around town. I'm wondering if I should change the Injection Timing ECT adjustments at all (Tables B0913 and B0915). I left these as they were stock, and with the cold weather approaching I'm thinking I should probably adjust these tables to back off the timing when coolant temp is below operating temparature. How is an engine going to react to 25* of timing in sub-zero temperatures up north? On the same note, that timing is set to come in at high RPM, which these engines will not see until up to operating temperature. Just wondering if you guys adjust these?
