LLY: Injection Pump?
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
I'm kind of at a loss right now and really need some advice ..
This LLY is getting fuel all the way past the fuel filter(you can prime it untill it feels really firm). The truck will crank and crank and will NOT start. I spent a good share of the day at the dealership and they are thinking either a bad injection pump or a bad injector. Brand new fuel filter and fuel tank is full BTW
The only signs i noticed a couple days before was excessive black smoke, hard to start, etc.
I would like to check the injector balance rates but the truck does not start...
Would the truck actually not start if all that was bad was the Injection Pump?
Here are my codes if you are interested:
C0035
B2600
U1000
U1016
Thanks for any advice you have. I just need a little technical support before I start replacing expensive parts..
xcablb7
Feb 8, 2009
536
Fall River
Its not really a recommended practice but sometimes can light it off with starting fluid and then it will stay running on its own. Sounds like a bad injector though since it was smoking before it died
blackdirtymax
Apr 15, 2010
825
augusta, ga
It was black smoke.. not white.. idk
Thanks
Why don't you take The v2 and see how much rail pressure your getting while cranking it over . I think it needs like 600 or 700 psi to even try to start , that will tell you if you have a bad cp3. If I am wrong on the numbers someone please chime in , it's been awhile
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
1 more thing dont forget to pull the fuel injection fuses so they wont spray,whatever glow plug hole is spiting out fuel thats where your problem is
