injecter rates differnt after head gasket job
stumpman750
Feb 20, 2012
40
hey everyone, i got lot of issues since my head gasket replacement. i was wondering, if it could be possible the connections going to the injectors are dirty causing diff readings, also, what is this all about "ice Picking", i looked at that thread, and understand why they do that, is this something that i should do to, and just to clarify my questions on what pos numbers mean and neg numbers mean. +4 mean adding more fuel, or does -4mean its adding more fuel.
#1 is 2.2,
#2 is -4.6
#3 is 0.6
#4 is -5.2
#5 is 3.6
#6 is 1.2
#7 is -0.4
#8 is 3.0
before head gasket job every injector read +/-1. is this a wiring issue, bad connections, ice pick issue, or what. everybody around my area are stupid stupid, dumb. what do you think? also, which side of engine are, 1357 injectors on, and 2468 injectors, from front to back of truck or other way around? I am trying to pinpoint my problem.
13,713
775
A positive number means the ECM is adding fuel to the base injection amount, and a negative means it is removing fuel. The cylinders are numbered from front to back with the odd numbers being on the right (passenger) side of the engine and even being on the left. It isn't likely that doing the ice pick fix will help your balance rates. I would do a compression test to make sure it isn't loss of compression causing the change in balance rates.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
1 is the front ps. 2 is the front ds and so on.
Edit never mind I need to start reading the replys before I post
Sent from my PC36100 using Tapatalk
stumpman750
Feb 20, 2012
40
Just a couple of these replys just posted about which side is even numbers is contradicting the other post! Which one is it,ha ha ha
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
That must be something else on them. You can put new injectors in any cylinder. but tracking down problems or assembly etc you need to know what cylinder is what.
wilsonck
May 8, 2008
206
Calgary, Ab
That's what I thought. My question wasn't thought very well due to posting from phone. I knew odds were on passenger side. It should have been along the lines of does it matter where the 1357's go compared to the 2468's? Also when you order, you dont specify these numbers.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Your phone is confusing you ;) . The injectors don't care where they go... If they are marked 1357 and 2468 on the body for some reason, it's just a coincidence. Above they are referring to specific balance rates of injectors from cylinders 1357 & 2468.
