In/Out CP3 shaft play
The Kansan
Aug 30, 2013
179
Topeka, KS
Hey guys i meant to ask this question the other day but i have my good ol trusty 187,000 mile modded cp3 thats still kickin but when i had it off i noticed some in and out play in the shaft. Its running fine no leaks or anything. Is that normal? I was gonna use it in a dual cp3 setup but if its about shot ill just go with a 12mm pump instead. Thanks
3,727
296
I don't recall mine having any significant in/out play when I pulled it off at 290k miles.
With the miles on the pump, and the shaft play, I would personally be inclined to go with the 12mm pump. I have a 12mm Exergy on my truck, and besides being a bit touchy to tune the FPR, it is a beast.
However, if you already have the dual CP3 kit, stick the new(est) pump in the valley, and then if this one takes a crap, it is easy to swap out.
The Kansan
Aug 30, 2013
179
Topeka, KS
However, if you already have the dual CP3 kit, stick the new(est) pump in the valley, and then if this one takes a crap, it is easy to swap out.[/QUOTE]
Haha This is exactly what i was thinking. I run a single pump in a remote setup right now so i have the dual cp3 mount that i built and a hard line that i bent up for it but i dont have the controller. Have there been any longevity issues with the bigger stroker pumps or are they pretty reliable?
