In need of a stout engine stand
moparkxracer
2,309
33
Out and about
I got mine from harbor freight for abt 90. The stand didn't droop any when the engine was out on it. Mine is not a side mount one though.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
I've got six of the harbor freight stands in constant use for several years now, never had an issue with full weight motors. I use a 1/2" plate bolted to the motor mount area on the block, with a pipe cut @ 45* welded to it (14" long on the pipe). Hot water heater pans fit nice under the legs of the stand.
Cougar281
1,809
253
St Louis, MO
The Harbor Freight stand is stout. http://www.harborfreight.com/2000-lb-capacity-foldable-engine-stand-69521.html
I strapped a washing machine pan onto the legs to corral all the fluids, too. Worked very well.
That's the same one I have and yes, it's very stout. No issues with a fully dressed duramax. The only thing I had to do was take a grinder to the weld inside the tube on the stand that the engine adapter slides through. The weld was REALLY rough and made it pretty much impossible to torn over.
Sent from my 831C using Tapatalk
baddaddition
Mar 10, 2013
287
Are ya decent at fabricating? I made this in an afternoon. Works great. uploadfromtaptalk1445388989899.jpg
Sent from my XT1254 using Tapatalk
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Your welcome to use mine if you want to drive a little ways to get it.
baddaddition
Mar 10, 2013
287
Ha-ha um ya I could... Shipping might be a bit pricey, but they could probably go for 350$ sound decent? The bearings are the expensive part.lol
baddaddition
Mar 10, 2013
287
I just tired of working my ass off trying roll them, and it is the perfect hieght.
Awenta
4,090
CT
Where you located? I'll just come steal yours and you can make yourself a BRAND NEW one!
baddaddition
Mar 10, 2013
287
Bahahahahahaa central IL. If I keep this routine up I'm gonna have to build another. I have two o. Stands I e build. The grey side mount one and the first gen I built 6yrs ago that is a standard engine stand on steroids. Then the third motor is on a nice wood roll around but ya have to have the pans off the set it down. It's more for the parts motors, or the grenaded ones.lol
baddaddition
Mar 10, 2013
287
Hey,since you usually catch me on my details... Lol anyone know where to find the info on rewiring for an AF cam for lb7? I did mine already, but just wanted to do some more rand d
