Importance of hood ground?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
The strap that grounds my hood broke and I was just wondering its purpose and if I should bother to replace it?
Sent from my iPhone.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
The light for sure but of course that got dropped. I'm thinking maybe for static charge build up to prevent a spark from a crash or something.
Porno Joe
513
South of Pittsburgh
Totally useless. Have no idea why gm puts one on.
I've been running without one for 2+ years.
Your hood is still grounded thru the hinges since it's all metal on metal contact
The truck I did have with an under hood light didn't even have a ground strap.
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
I know mine never came with a hood strap and I have (had) an underhood light. But think the wiring for light had a ground in it.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Its not for the hood light...because obviously 03+ trucks dont have an underhood light (so why would GM keep the ground strap there?). And second of all, on the 02 and older trucks that did have a hood light, the ground was separate (the lights had two wires going to them, power and ground). So the ground strap for the hood was/is for something else.
The only thing I can think of is maybe in case lightning hits the truck, or for some sort of other electromagnetic shielding? FM radio interference perhaps? Who knows. But its not for the underhood light.
Ben
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Off it stays then, i'll report back if I notice anything different with radio reception etc. I already get very clear radio and I don't even run the antenna...
13,746
821
I heard somewhere it has something to do with AM radio reception, but who knows.
6,016
i hear its the fusable link for beating the Limo. without it, there is no chance of it
blkdmax04
loud pipes save lives
Sep 7, 2010
205
The Desert
One reason is so your truck acts as one piece .. have you ever seen a electrical weld its what you get with a loose connection it starts arking and heats up and melts the metal together , so with out it if you're truck ever got hit with lightning or got energized some how your hood hinges would act as the connection then they because they move and not being a tight connection would weld together in whatever possession they where in
Sent from my SGH-T999L using Tapatalk
15,681
233
I think its there for stray electromagnetic signals that could influence electronic throttle control and other things.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I've been snooping around the net and that's what the consensus seems to be. I even came across some stories of cars that would die when crossing under big power lines. Repeatable. And fixing the hood strap fixed the issue.
The things you learn... :D
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I broke mine off when I put the hood in the service position when the engine came out :rofl:
no radio, no problem!
