LB7: Im Losing My Mind
RobsDmax
832
Arthur, Ontario
Alright so here comes a story. I have noticed a clunk or thud of some sort letting off the throttle at about 60 mph. It gets worse the faster i go. Almost seems like i am hitting a bump whenever i go from half throttle to zero. if i ease my foot off the pedal it doesnt happen. Thought it was the slip yoke, so i pulled the driveshaft, lubed splines, checked u joints and trans mount. all seem fine. had both front wheel bearings done as there was wheel play when i had my driveshaft out. this is still happening. thought it was axle wrap, clamped springs and didnt help. so i got a mechanic to both ride with me and drive it. he says he cant feel anything and its normal. Is this just the torque of the truck and am i just losing my mind? I noticed a clunk leaving stop lights today. but that seems like the caliper and or the parking brake. this clunk is driving me up the wall, if its normal maybe i will calm down.
5,911
Male ssure your torsion bar bushings are not shot, might also make sure your trans crossmember is tight at the frame
RobsDmax
832
Arthur, Ontario
now that you say the t bar bushings, i let my keys down for pulling and the one side i could move the bushing in frame with bolt out, and other side wouldnt move...
