LMM: I'm a rookie upgrade parts
cr4zygui
Apr 29, 2014
Jonesboro, GA
I got a bone stock 2007.5 lmm and need some help. This is my first diesel and have no clue about it. Heard lots of good stuff about efi live and deleting my dpf to save fuel(my main concern) plus gain some hp. I live just south of atlanta and if anyone can help me out. I got a tight budget so if I can, I want to go the most important path but best way to spend my money. Any assist will be great. YES I know I should've search the forum but since I've joined the forum I been trying to and can't seem to get the answers i was looking to get.
Thanks
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Budget conscious upgrades:
Use the "PPE stock air intake mod" - free
PPE high flow CP3 kit and PPE ported rail fitting for the Drivers side rail (only!) -$100 for both
4" turbo back diamond eye exhaust - $300
Batmowheel turbo upgrade - IIRC, about $350
TransGo Jr shift kit -$100
Single 100hp tune EFI tuning from a reputable vendor - anywhere from $150-$350
Cat or Baldwin 2micron fuel filter to replace the stock filter- $65 comes as a kit IIRC that adapts the filter housing to accept the cat filter, not sure tho, could be able to run the filter on the stock housing
Beyond that stuff, I'd suggest getting a lift pump to supply the CP3. Maybe "instead of" the single tune you could get an AutoCal with dsp5 switch and multiple tune programming, but just between the lift pump and tuning you can easily be into them for over $1000.00 where as with a cat filter and a single tuned ECM you be into those about $350
cr4zygui
Apr 29, 2014
Jonesboro, GA
Coco I love the idea of the 5 switch. What would you recommend? I know I'm cheap but 1300 I s hard to come by nowadays. You mentioned plenty of good stuff but what would you do if you only had 1300 to spend? Fuel economy is the main concern atm.
Hot COCOAL
Jun 9, 2012
4,433
If frugal is the key point here, then I'd skip the DSP-5 switch and get a single tune
Maybe just a tow tune if the truck does work. And make sure the tuner knows you're deleting the DPF.
That'll save ya a couple hundred right off the bat, the tow tune would probably net the best economy but economy and mods don't "always" go hand in hand.
Get the cheapest exhaust you can that deletes the DPF, that's why I mentioned diamond eye, as last time I checked their prices were the cheapest and all the exhaust is doing is moving gases, it doesn't have to be expensive. Between the PPE intake mod and the DPF delete and 4" exhaust that will probably be where you'll gain economy.
I mentioned the minor fuel supply mods cuz you're going to be demanding more fuel with the new tuning and the stock filter doesn't filter down to a small enough micron level.
With the added power comes added trans stress, and the Allison is finicky, and can't take much more in stock trim than 60whp before you can cause issues. At 90+ WHP things can get dicey and it's kinda luck of the draw and how you drive, so I'd highly reccommend the shift kit, for even tow tunes can reach 90whp over stock power. The Allison is a great trans but it does have limits and one of them is it's a learning trans, so it stores shift values then predicts needed values for the next shift. This is great except when you want to change power levels on the fly, which is one benifit to just getting a single tune.
So, $1300 to spend-
PPE intake mod- free
Tune- 250
TransGo- 100
Fuel filter and filter kit- 65
Exhaust- 300-400
Ported rail and hi flow CP3 kit- 100
You're at
$815-915 give or take and various shipping charges probably will add up to $1000!
That mod list falls into your spending amount.
You could afford the DSP-5 tune and switch, but that will give you enough power to damage the trans if you're not careful, but it is fun to have the power! Just remember he trans learns and you don't want to switch to the race tune at a light and mash the to pedal ;)
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,198
362
At Da Beach
Flo pro exhaust, EFI tune installed from a local so you don't have to buy an Autocal, egr blocker plate and a FPRV shim. That shouldn't cost more than 750.00 total...
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
Lots of people do a shim kit but I'd hold of until you know you need it. My LBZ has over 200, miles on it and has been at or above 500HP since 10k miles. My shim kit is still in my glove box.
cr4zygui
Apr 29, 2014
Jonesboro, GA
Do we have a good guy in an around my area? Looking for someone I can trust to do the job right the first time. I really don't care too much about power but I know I'll need the tow since I tow my trailers during hunting season and boat for fishing and summer rides.
So which exhaust should I get?
Efi live? Do I need the controller thingy? Now I will need to figure out what is a transgo and mostly what coco said. Need to find a good tuner now. I can install the exhaust myself. I'm pretty good doing stuff like that.
Thanks for all the inputs and more would be great. I will try to find a local guy and show him this list I got and see if he/she agrees with most of it.
moparkxracer
2,309
33
Out and about
I have a used exhaust I'd sell fairly cheep, it is located in North Carolina. It's a banks dual tip. I had it on mine before going to a single 5 inch. If you where willing to make the drive you could call Dustin at diesel addiction he is awesome at tuning and would answer all your questions. There are a lot of members on here running his tuning.
blue09dmaxx
Too broke for this shit
Jan 15, 2012
823
The south
I'm in greenville sc and will help you out
