Ihi internal part of WG
Yngdmax92
962
Can the flap on the back side of the turbo be replaced? Mine is a modded 63.5 and the waste gate flap decide it did not want to be part of the turbo and shot out my exhaust. Thanks
bonomax
223
Hermitage, PA
i had two LB7 turbo go bad on me. one was original turbo with 100k miles on it, bearing went bad and chewed up compressor wheel bad. second one same as you broke waste gate flap off. So I got used turbo took the hot side off and had it modded back to old hot side specs port and polish. sucks i know thats not cheap fix. Y i decided i had enough problems with LB7 injectors then LB7 turbo problems and swap everything to LLY.
Yngdmax92
962
mpsoldier1 sent me a new exhaust housing and took care of everything for me. I split it and put it back together, wasnt that bad of a job i would say. Very impressed with his work and his customer service.
