It is called 2009 Airstream PanAmerica 34' Toy Hauler Travel Trailer
[YOUTUBE]mAgplo7Ok2Y[/YOUTUBE]
Designed for the adventurer that wants to explore every mountain road and open highway, the new 34-foot 2009 Airstream PanAmerica can haul two motorcycles, ATVs or other action/adventure gear, up to 3,000 pounds worth. The rear 11 feet of the trailer is configured as a garage, complete with a durable aluminum interior skin and textured floor. A gull-wing exterior door with fold-down ramp has been incorporated into the trailer's tail, and a pass-through door in the bulkhead with porthole window gives occupants access to both rooms. The back room is also equipped with storage cabinets, tabletop work areas, tiedowns, electrical outlets for power and speakers tied to the PanAmerica's crystal-clear sound system.
The fully equipped living space offers contemporary European luxury yacht-inspired design with flush cabinetry, flowing lines and indirect lighting. Stainless steel appliances and trim, leather appointments and a flush-mount flat screen television make this an extremely comfortable RV.
Model: 2009 - 34' PAN AMERICA TOY HAULER TRAILER
Chassis
11,500# GVWR - 11,400# Axle System - 7,225# UBW - 4,275# NCC - Aluminum Wheels - 15” Radial Black Wall Tires, LRD - 12” Electric Drum Brakes - 3,500# Electric Hitch Jack - Manual Stabilizer Jack w/Pads - Aluminum Step w/ Extension - Stainless Steel A- Frame Protectors - Spare Tire & Bracket.
Exterior
Bright Aluminum Finish (White Finish on Roof) - Exterior Graphics - License Plate Holder w/Light - Grab Handle - Enclosed and Insulate Underbelly - 21’ 4.5” Patio Awning w/ Center Support Arm - C.S. & R.S. Awning Rail - C.S. & R.S. Rear Underbelly Storage Compartment - LPG Bottle Cover - Solar Stone Guards - Wrap Protectors - LED Tail Brake, Turn Lamps, Clearance & Marker Lights - Diamond Plate Exterior Storage Compartment Floor
Utility/ Garage
94” W x 132” D - Fluorescent Ceiling Lights - Interior Passage Door w/ Porthole Window to Living Area - Skylight w/ Blackout Shade - Rubber Coin Flooring - Pull Roller Shades - Entry Ramp- Pull Out 55” W x 64” L
Windows & Doors
S.P. Solar Grey Front Panoramic Windows - Opaque Door Window - C.S. Front Access Door - Screen Door Guard - Keyed Deadbolt at Main Door - 30” Vista View Window - Skylight w/ Blackout Shade - 3-30” Portal Windows - Rear Gull Wing Door 52” x 64” x 2 - 30” Portals & Ramp Light
Interior Décor
Full Close-Out Drapes at Panoramic Windows - Aluminum Interior Skin - Wood/ Steel Drawer Boxes - Gold Alchemy Laminates - Pull Roller Shades - Overhead Rooflockers w/ Radius Doors - Entrance Mat - Hardwood Threshold - Vinyl Flooring- Laminate Tops w/Aluminum Trim - Interior Assist Handle
Bathroom Décor
Towel Bars (2) - Towel Ring - Hinged Bath Hall Door - Foldette Privacy Door - Fiberglass Shower w/Molded Seat & Glass Door - Countertop Vanity Cabinet - Shower Light - Stainless Steel Round Lavatory Sink - Mirror- Articulating Swivel, Double Sided w/ Magnification
Bedroom Décor
Removable Bed Storage Boxes - Quilted Bedspreads - Foam Mattress - Bed Pillow (2) - Lift-p Bed Storage - Front Overhead Rooflocker - Queen Bed Model has 60” x 75” Fixed Island, Under Bed Storage, Nightstand Forward Bedroom, C.S. Wardrobe w/Light, Throw Pillows
Galley Décor
Stainless Steel Single Bowl 18” Round Sink w/Cover - Faucet w/ Pullout - Recessed Bi-Fold Range Cover - Perforated Metal Refrigerator Inserts w/ Accent Panel - Galley Overhead w/Radius Doors - L-Dinette 42” x 76” w/Hi-Lo Pedestal Table (Converts to 42” x 76” Sleeping) - Decorative Lamps w/ Perforated Metal Shades (2) - Pantry Storage
Appliances
13,500 BTU Air Conditioner w/Heat Pump & Electronic Controls - 34,000 BTU Furnace w/Electronic Ignition - 3 Burner Cooktop w/Convection Microwave Oven Below - Fantastic Roof Vent in Bedroom & Utility Room - Bathroom Exhaust Fan - 12 Volt - 7 Cu. Foot 2 Way Automatic Refrigerator - LPG, Smoke & Carbon Monoxide Detectors - Fire Extinguisher - Probeless Tank Monitoring System w/Display Panel - 6 Gallon Water Heater (Gas/Electric) - XT Series - Equivalent Output of a 9 Gallon Water Heater - Range Hood w/Vent - Comfort Control Center (CCC)
Entertainment & Sound
Radio Antenna - AM/FM/CD Control: 18FM/12AM Presets, 52W x 4 High Power Output & Dull Detachable Face & Remote Control - 6 Speakers Wired and Mounted w/A-B Switch from Utility Room to Main Living Area - TV Ready: TV Antenna, TV Jack - Cable TV & Telephone Package Includes, Amplifier w/ 12 Volt Outlet, 2 Cable Outlets & Telephone Outlet - Prewire for Portable Satellite Dish
Electrical
Deep Cycle Batteries (2) - 7 Way Trailer Plug w/Junction Box - 30 Amp Service w/ Detachable Shore Cord - 12 Volt Breakers - 110 Volt/30Amp/12 Volt Power Center w/55 Amp Converter Includes 12 Volt ATC Fuses (Combination Unit) - 12 Volt Halogen Lighting in Ceiling in Living Area - 12 Volt Fluorescent Recessed Ceiling Lighting in Utility Room and Under Galley Locker - 120 Volt Exterior Outlet - GFI Protection for Galley, Bath & Exterior Outlets - LED Step Light - Patio Light - Water Pump Switch in Galley - Electronic Battery Disconnect - Exterior Lighting Package, Hitch, Dump Valve, Exterior Compartment Lights & Rear Area Light at Ramp Location - Solar Battery Charger Prewire
Systems
30# Aluminum LPG Bottles w/Sight Gauges (2) & Remote Deluxe Panel - Automatic 2 Stage Regulator - Shower Head w/Shutoff - Water Heater By-Pass Kit - Galley Sink Spray Head - Lockable Water Fill - High Volume Water Pump 4GPM - Water Pressure Regulator - 54 Gallon Fresh Water Tank w/Drain Valve - 39 Gallon Black Water Tank w/Tank Flush - 37 Gallon Grey Water Tank - Sewer Hose Storage - Ducted Heated Tanks - Exterior Hot/Cold Spray Station - Overall Length 34’ 7” - Exterior Width 8’ 5 1/2” - Interior Width 8’ 1” - Exterior Height w/Air 9’7 1/2” - Interior Height w/ Air 6’ 5” - Hitch Ball Height 19.75” - Hitch Weight 1,260# - Safety Chain Hook 11,700# Rating
But they are around $90,000 USD
