I know the cost of this build is going to be great but I've been trying to do things a lill at a time to help with the pain my wallet will feel. I've done have my cp3's just haven't decided on a large single or going duals. I'm also wondering on what size injectors I should go with. I'm setting a minimum goal of 800 hp with room to grow. I know my twins will start to be out of there range at these numbers. so I'll probably upgrade those as well depending on budget, but my main questions is what needs to be done when getting the internal parts together and what is just a waste. What's the main things that are a must. This is what I'm planing on and please add to this if I've missed something.
Stock crank(keyed)
Stock cam (keyed, unless I go with a socal cam)
Carrillo rods
Block ( stock bore, torque plate honed, cylinders and main journals)(arp main studs)
Water pump (gear welded to shaft)
Grade "C" head gaskets with Arp studs.
Stock pistons cut and coated
Stock heads ( I've got a friend that machines heads and thought about having him work them over. just wasn't really sure what's needed and what might hurt them) any advice is welcome.
Also I'm going to be building this myself are there any tips or tricks that might help this build go as smooth as possible?
Stock crank(keyed)
Carrillo rods
