i want to convert my '93 blazer
shmeeh
Feb 4, 2012
Hey i want to convert my '93 Blazer to Diesel. I want to put a duramax with an allison transmission, but i am not sure what all i will need to change out.
gr8shot
Practically stock
Apr 28, 2009
262
3
Grand Island, NE
If you have to ask then its probably a lot bigger project then you want. Look into putting a 12v cummins in it. Its a much easier swap than a dmax/Allison.
Sent from my old skool Droid
schulte
Jul 31, 2010
449
CT
Body wiring harness, fuel lines, transfer case, axles, steering column, dashboard, ECM, TCM, radiator, intercooler, brake booster, accelerator pedal, and 4x4 module/switch. Just to start with.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Some of these yes, but not all of it.
What he said. It is NOT easy, and not for the average weekend warrior either. This will give you an idea. http://www.thetruckstop.us/forum/showthread.php?10142-95-SUBURBAN-to-a-01-DURAMAX-ALLISON
you may also want to consider the smaller 4 cylinder ISUZU diesel for it as well. http://www.thetruckstop.us/forum/showthread.php?32348-Isuzu-4BD2T-diesel-swap-into-Suburban
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
stock axles will work if you dont beat on it, definitely NO need to swap steering columns, body harnesses, dashboards, and brake booster (assuming the blazer was diesel to begin with?).
All that stuff is fine...waste of time to change that, but as Ferm said, it is a big job.
