A buddy of mine bought an 01 with 174k on the clock. It's got quite a few mods including 240hp II injectors, unknown sized cheetah, trans, ancient lift pump, and it doesn't have head studs. It's only running roughly 30psi of boost.
Well the issue I have is it blows coolant. I'm obviously suspicious of a head gasket. with no pressure on the vent cap and truck off, you can put the cap back on start it for 30 seconds and shut it off. Truck will pop the cap off as you unscrew it, and blow out what coolant it can. Also balance rates on 2 and 7 are shit, idling around the 4 range i believe. lastly and this is where i'm really curious about is the oil pressure is high as hell. The oil level is fine and doesn't look/smell funny but the gauge is reading 80psi when warm.
I'm leaning torward a blown head gasket or two, and a bad stepper motor on the dash?
Thoughts? I don't have access to a leak down kit, but I told him to get the coolant test kit. I've seen mixed opinions of the kit, but figured if it came back positive that would be one more indication of a bad HG.
