i recently put a racevalve in because of low rail pressure codes and now its worse what did i do wrong?????
:hello:Well if you don't have a fuel leak out of your rail around the plug, it shouldn't be anything to do with your install. You could have an FPR problem or a rail pressure sensor issue.
Fill out your sig. It makes it easier to help you if we know what else you have going on. I.E. Dual CP3's, EFI Live or Edge, etc.
