All the fuses are good, truck runs if i jump the starter but when i turn the key over all the way to crank her up she does nothing. She doesnt click or turn over. Just a dead silence. What would cause this?? Thanks for your help.
Maybe your truck is not reading neutral... Try moving the shifter as you turn key????? just a guess
1st id check is take ur test light and see if your gettin crank signal at the starter solinoid
