LB7: I need help I turn the key and I get nothing no cranking of the engine
lobocharlie
Apr 10, 2011
29
Albuquerque
I was tiring to start my 03 lb7 it was about 25 degrees and batteries went low then something made a noise and now when i turn the key I don't get any crank or turn of the engine It reacts like if it is in gear and try to start nothing. I bought new batteries they were not connected for 1 hour?
I have power to:
lights flashers radio wipers dome
I have no communications on the dash like the mileage
I have no glow plug
I check all fuses they are all good.
What happens when the ECM or TCM goes bad.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Is your Security Light on in the dash panel?
There is a component on your transmission that verifies you are not in gear. NSBU? or something like that. These often fail.
lobocharlie
Apr 10, 2011
29
Albuquerque
I can still lock and unlock with the remote?
I only see the security thing when i use the remote. When I turn the key I don't see anything.
How do i reset the security?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
You can reset the security with a Tech 2 or EFILive, but that's probably not it if you turn the key and the security light isn't on.
That transmission safety switch could be to blame. ECM's don't die easy, and a truck will start without a TCM.
lobocharlie
Apr 10, 2011
29
Albuquerque
Where is the best place to purchase an ECM
That is what I was thinking. Where is the best place to purchase an ECM and not form the dealer? Thanks for your time.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Guessing at parts is pretty expensive.
You need to post something like:
New Mexico: Need Help!!!
We have several very smart Dmax hotrodders in your area.
A fresh ECM ain't cheap, and it might not fix your issue. If it was running, it's probably something minor.
paint94979
Beer Nazi
Sep 18, 2006
11,715
x2!!!
Operator1
477
NC
Will it start in neutral instead of park? We had one at work today with a similar problem, it started right up in N.
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
First off... Go Lobos! Haha being in the top 25 sure is nice.:thumb:
Brannex out on Brodway is decent for a used ECM. If you want a new one I can get a decent deal from the guys @ Galles Chevrolet. I live in Taylor Ranch. PM me if you need help.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
Since you said you don't have any mileage readout on the dash, do any of the dash lights do their bulb check when you turn the ignition on? PRNDL readout showing anything? Does the Check Engine light turn on when first turning on the ignition? Quite possibly an ignition switch failing and not sending voltage to the ECM.
lobocharlie
Apr 10, 2011
29
Albuquerque
I had nothing so::mad:
I removed the ECM yesterday in the am because I was going to order one. I also plugged in the Block heater last night because it has been really cold.
:confused:
SO when you asked about the lights I just walked out and put the key in turned the ignition and everything powered up.????:confused:
The security came on the gauges reset,The read out showed mileage.:confused:
So the switch is working.
I put the ECM back in and everything still displayed but no start.
I think I am going to try the 30 minute security reset and see where we go form there. I give an up date in a few.
Thanks for everyone's input in advance it is very much appreciated
chevyburnout1
Aug 25, 2008
2,368
Berthoud, CO
Is the Check Engine Light turning on when you hit the key? If so go ahead and try that security relearn. Is there a line under the 'P' for the PRNDL readout?
lobocharlie
Apr 10, 2011
29
Albuquerque
I tried the security still no start.
The Check Engine is very very dim when i press the break it get brighter
what is the PRNDL? there is a dash line under the P in the trans selector window.
The gauges cycle all the way to the right then back to normal.
I have an old Snap on Mt2500 red brick and I use to be able to run the function test like A/C relay, Check engine light and it is not running any of them now.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
I guess ignition switch. If you put a ECM in on a guess you are NUTS. I'm a tech and there is a saying in the business. "Its never the computer" and ive seen it proven true often!
chevyburnout1
Aug 25, 2008
2,368
Berthoud, CO
A dim Check Engine light I would look at power and grounds. Especially if this happened right after cranking on it a few times. Good possibility of ignition switch or a poor ECM ground. I can give you what terminals to check at the ECM if you want to check power and ground.
chevyburnout1
Aug 25, 2008
2,368
Berthoud, CO
If you have a multimeter you can do a quick voltage check at the fuse block. Check to see what the voltage is at all the ECM/PCM and IGN fuses with the key in the on position and the batteries charged up. If the ECM can still communicate, someone with a scan tool could also look at the ignition voltage in the data display.
