ok then a few questions to get me started looking. Will all year hd truck swap if i were to find one in a scrap yard? then what cab configurations will work ? mine is a CCSB should i look for the same or will others work?
the rear, i had a u joint go bad and it ate up the end towards the rear diff it barely holds the clip in now and i want to replace it before it quits on its own.
It will have to be from an lmm truck with the same cab/bed configuration as yours. The lmm uses a 1480 series u joint, & as far as I know, all previous years used 1410 series u joints
