I need to find a 0-5 volt digital output to control a pump. I need this pump to speed up when MM3 required goes up. I was wondering what I should use to control this. Would the TPS work? Maybe some sort of boost or MAF signal? Basically, as MM3 goes up and down I need the voltage to go up and down-more voltage, the faster the pump turns.
Does anyone have any ideas what I can use that is already on the truck, or what sort of sensor I can use? I could use a potentiometer mounted on the dash, but I want something automatic.
Thanks
Thanks
