D
Deleted member 32467
Guest
3 months and thousands of dollars later...
I fired my truck for the first time last night with borrowed batteries as my new ones had been ordered. While re-routing cables tonight, the new passenger side battery was connected and I think I drug a drivers cable across the TCM. I remember seeing a small spark.
Sure as shit, no crank anymore. If I lean the TCM against the negative post it starts but dies after a second, dash says something about reduced power. I have no continuity between pins 9 and 69.
Is the dying after it starts normal? I see threads where guys solder a lug from the TCM case heat sink and the battery negative terminal or body ground and go on there way.
Where do I get a TCM like 911? Overnighted, drive across the state (Utah) tomorrow, whatever. Does the new TCM have to be programmed for my VIN somehow?
Supposed to drive across the state pulling all my families toys next week. I am not even mad, just super disappointed in myself, and GM for putting that metal heatsink case right by the battery.
Thanks for any help.
I have cross posted on forums, but I am desperate for quick answers. Thanks fellas.
