I have access to Monotherms but....
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I don't think they will fit :rofl:
Cat 3516 long stroke Hd Rod and piston assembly. With a R&R rod & stock rod for comparison.
Monotherm & a stock cut and coated LB7 Piston.
Anywho I thought it was cool looking at the size difference...
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Lol I have the same 3516 rod and piston in my garage thought I was the only one :D few cracked pistons from a 3406 too
Have a c175 20 cylinder getting ready for dyno testing next week at work.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I have to give this one back:mad: Fuggers think there is a core charge or something:D I'll have to figure a way out to steal one... I mean borrow one with no intention of returning it.
Maybe you can borrow the counterweights instead of the whole crank:D
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Must be the picture then, looked like the old short stroke pistons, but if it came out of a 793D then its gotta be the HD setup. I just finished in-framing the front engine on a 797 today actually
Maybe you confused the stock d-max piston as the cat piston... It happens:D
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I have pics of one somewhere that removed themselves in truck... It wasn't pretty.
I had to tear a 3516 down from a failed crankshaft, turns out it had the wrong TC adapter and f'd the thrust bearing, broke the crank in half after #6 rod journal, had to cut the end off of a rod cap to get the crank out because it wouldnt spin over. had 3 bent rods that looked like tacos ;)
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
Brain, we have a few pieces of cat equipment at work. We have a 385 excavator with a long boom and clam bucket. We also have two 980h front end loaders. What motors are in these?
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Not Brian but Im qualified to answer. Depending on what model 385 you have... C15, C18
980H C15
