but hate trying to eliminate it more. i am so farking stupid with this tbiq table it is not funny. i now have a shift that accelerates then defuels. i adjusted in minimal amounts and then went back a little. so now the few cells i changed are no more than 2-3 numbers higher. the problem is it is calling for a defueled torque number that is not on the axis so your adding fuel to a cell that it really isnt using. so for instance i am getting a request for 132lb/ft and my choices are either 187lb/ft or 74lb/ft to change. it is highlighting the 187 table and cell for the specific rpm but the actual defuel mm3 it is using is lower than what is highlighted in the cell. what gives??? in my log it is cutting fuel to 25mm3, and the tbiq cell reads 35mm3. how do you fix a defuel when the matched cell on the scan/tune tool are differant numbers? where am i going wrong?
