Question: I got a water leak
DougSmith
I got a leak on the drivers side at the corner of the fender, windshield, and door jam. Originally I thought it was through the rubber piece that houses the wires that goes into the door, I checked that toroughly and it is good. "
I ran water out of a house on the corner of the windshield, and within a couple seconds water started dripping inside, down around the hood release. There is a dead space between the inside metal and the outer sheet metal that I can not see, where the water runs in and puddles and then comes out a hole just bleow the hood latch on the inside.
Anyone got any ideas where the water would be going through at? the windhield is not leaking, it is somewhere in the corner below the edge of the windshield.
06 GMC CC LB LBZ
