Guys, being a little bit anal retentive, I wanted to use the body junction block on my LB7 (2001) to power some gauges and accessories. I got the idea after installing my trailer brake controller and noticed several unused connections there.
I searched quite a bit to be able to find the 6 way connector that matches the one used on the trailer wiring harness. Many of the aftermarket SEOs use these connections.
Finally I found them on the Mouser.com website. Here are the part numbers.
12193930 - connector
12193931 - locking pin
15324339 - terminals
Note that the terminal listed above is for about 14-18 gauge wire. Other terminals are available for larger wires and the connections are good for 30 amps I believe.
Hope this helps someone who wants to either build their own trailer brake controller or use one of the other connections to power accessories.
