I built my motor 1,200 miles ago. For the last 500 or so miles, I've been noticing my coolant go down every time the truck sits (but not while driving, even hundreds of miles). After sitting, it would sometimes smoke white. I suspected coolant leak, but the radiator hose wouldn't stay hard, and no bubbles in the coolant tank.
I got one of the coolant pressure testers, and put 15 PSI into the system with the motor off for 10 minutes. It leaked down about 5 PSI. Released the pressure, and went to turn it over. Nope, hydrolocked.
So, the coolant is going into one of the cylinders (I will figure out which one this weekend). But how? Normally with bad cups or headgaskets, you get bubbles into the coolant. But mine is not doing that.
How would I know if a cup or headgasket is the problem? If I can just replace/reseal a cup, I would rather do that. (Pulling a head off sucks.) Do I just hope the cup comes out with the injector, then assume that was the problem?
