So my Hydroboost is leaking from the accumulator. I'm planning to replace the unit and bleed and replace the P/S fluid and brake fluid while changing. I've seen just a couple of comments stating these units can be swapped with a 2011 unit. Searching didn't return much info. Can anybody confirm this? Other than being $180 cheaper on GMpartsdirect, is there another reason to make this swap? Does it provide better braking?
Thanks
Thanks
