Ever since I got my truck back up and running, I've had issues with the system. The truck sat in the shop for 2mos, before i had a chance to swap the motor. When I turn the heat or A/C on, it will run at temp for a while. After a bit, the A/C will go warm, and the fan slows. Same with the heater, at first it works fine, then cools down and fan slows. If I turn it off for 3-5min, then back on, it will work fine for a few min and then have issues again. Any idea HVAC guys?
