Should be a drive pressure issue if there is no other bearing issues. need to guage it and find out how much drive pressure you have compared to boost to see what the issue is. Do you have a blown intercooler? If you have a boost leak then you will not be opening the gate when you should becuase it is based on boost and that with toast thrust bearings in a heart beat if you are running alot of hp.
