Rule of thumb....
Make sure you have 1000psi in the tank before all runs!
Never hit the juice untill 20psi of boost is seen or 2000rpm!
If it stats popping Turn it off! Listen to your engine.
Back off timing about 4* or put on a low timing tune.
Make sure everything is routed and installed/working correctly.
Start small like .40 jet in a small nozzel 1/16 npt and try it out, watch out for boost #'s and egt's.
smoke is very important too, if you try this combo and it works well, all checks out, then look at your smoke level, if you have none leave it alone, if you do have a bunch, you can add a bigger jet or second stage.
This is as far as i would go with out accually being there to tune it. There is alot more to learn about nos, this is just the basic overview!
