heres my issue- truck smokes at idle and more than a slight haze off idle. clears up nicely once you are moving. I just put new injectors in it, balance rates are in spec so i do not suspect injectors are the issue
Truck has 40 over injectors and dual lbz cp3s
last night i took a log of desired vs actual rail pressure. according to my laptop, at cold idle( truck sitting for approximately 4-5 hours) truck was commanding 3500 psi and actual was 8700 psi. I unplugged my air dog, no change to rail pressure (though i may not have left it unplugged long enough).
this am on the way to work, i couldnt log the actual vs desired, but i watched the actual rail pressure on my aeroforce scan gauge. I noticed that a few times as i would pull to a stop sign, the rail would start decreasing, to say around 5k as i slowed down, and then when the truck came to a stop, it would jump back up to like 6-7k.
the 2nd cp3 was new in oct, maybe 5k miles on it. the one in the valley is original as far as i know with 193k.
Right now im suspecting regulator in the valley, but i dont know? could it be something with the dual pump controller?
looking for ideas on what it might be, or what tests I might be able to do/ logs to look at tonight to get this fixed
