How To Remove NBS Stereo
03 True Blue
Dec 31, 2008
15
Chino Hills, Ca
I tried searching, but didn't find much on removing a NBS stereo. I got a lockpick and need access to the back of the stereo. Does the outter trim ring pry off or are there any screws or other tricks I need to know about? Thanks in advance for the help!!
Also, this is an LT2 interior...
03 True Blue
Dec 31, 2008
15
Chino Hills, Ca
Nobody has removed their dash to get to the back of their stereos?? I am guessing the trim ring just pries off, but I would rather know before trying to pry and breaking thigs...
slowlmm
Mar 2, 2008
2,582
46
so cal
use a plastic putty knife or screw driver if your brave. start at one corner pop it out then move all the way around popping it out gentley and it will come right out. some of them are really tight. but those trim peices are verry strong. you should have no issues. then there just a few 8mm bolts holding the stereo in. good luck finding a place for the lock pick in there its tight. take your time and you will be fine
03 True Blue
Dec 31, 2008
15
Chino Hills, Ca
Got it done last night. Very straightforward with no problems at all. I ended up just using the tips of my fingers to pull out the plastic trim ring so I wouldn't chip it with a screwdriver. Thanks again for te help!! :)
