What? This is Duramax Diesels! Sure, if he stopped doing burnouts things would last longer, but where's the fun in that?
The G80 is a weak clutch style limited slip, and yours is just done. I wouldn't waste your money putting another back in. If you're on a budget, put the stock unit out of a Ram in it. That is just a lower ratio version of the Eaton TrueTrac. It won't work quite as well as the real TrueTrac off road, but is supposed to work pretty well all around.
If you have money, there are lots of options. A limited slip like the TrueTrac, an automatic locker like the Yukon Grizzly Locker, or a manual locker like an ARB. They all have their advantages and disadvantages, so it depends on what you want to use the truck for.
I have a TrueTrac in mine, and I love it. Spins both tires, climbs loose dirt hills, and actually puts power down in a corner without looping the truck out.
Sent from my Cat S60 using Tapatalk
