How to fix 0087
GraveMAL
Apr 19, 2013
Ok so I made a thread earlier concerning what I thought was a transmission problem, specifically a limped transmission. After running a check for DTC's using the a programmer, turns out it was a 0087, problem with a fuel filter I guess. Here is an explanation of how this happened, "Today I was driving my truck, a 2006 GMC Sierra 2500HD with Duramax Diesel and Quadzilla programmer, and decided to pass a car uphill(probably a little faster than I should have). As soon as I passed it, the check engine light came on. When I got to the next hill, I seemed like it didn't want to accelerate despite giving it gas. I immediately pulled off to the side and turned it off and back on. It started doing it again, not accelerating after about 50. So I put it into the manumatic gears for a little while. I then put it back in drive and it worked perfectly and is still working perfectly. The check engine light also turned off. This has never happened before". So my question is how do I go about fixing it. I would prefer not to lower the power settings for sentimental reason but will if I have to. Will simply changing fuel filter which is at 63%, and driving a little slower suffice in fixing the issue? Also should I clear the DTC?
