I mentioned this in one of your other threads, Do not shim the FPRV! That is not your problem and you can damage the valve installing it. My LBZ has over 200k miles on it and allot more modifications than your truck. I still have my stock untouched FPRV and I have no fuel issues. People do this as a prevenative mod and sometimes do more damage than good. There are test you can preform to check your FPRV but this more than likely is not your problem.
Alright, you guys win, shim it weather it needs it or not:hug:
I don't know the history of the OP's problems, but I tend to agree with you. I've never seen a low rail pressure problem caused by a FPRV on an LBZ or LMM. There are a bunch of people who have shimmed their rail and done nothing to fix their problem.I mentioned this in one of your other threads, Do not shim the FPRV! That is not your problem and you can damage the valve installing it. My LBZ has over 200k miles on it and allot more modifications than your truck. I still have my stock untouched FPRV and I have no fuel issues. People do this as a prevenative mod and sometimes do more damage than good. There are test you can preform to check your FPRV but this more than likely is not your problem.
