If your holding the input shaft and the clutch drum is above your hand it should be a small round hole around the base of the clutch drum. Dont take me 100% on this its been a long time since i have done this and I am sure Mike will chime in and tell exactly where the passage is on the clutch drum.
When you pressurize the clutches you will see them apply and release through the holes in the drum.
You will want to hear a solid thud when the clutch applys. The air check holes are on the bell housing below the pump at 5 and 7 oclock. Call me when you get ready.
