Used, around 7,000 miles or less in use. Big dipper nozzles. Balance rates grew since install, to close to the limit of +4, -4 over half the rest are less. I figured it was the higher mileage bodies crapping out on me. Possible high return rates??? Never tested em. Basically sending the bodies in for cores and if the nozzles could help someone else out I'd rather do that and take in a set of stock nozzles and/or + boot if they are worth it. Then send the stock set in as cores. Thanks any info is greatly appreciated.
Sent from my SCH-I545 using Tapatalk
