LLY: How much psi is to much for a lift pump
TRUBBS
461
Got a stock fuel pump off a 7.3l I was thinking about trying to run on my LLY with remote filters then feeding into the stock filter finally.
I'm not sure what it runs but I'm thinking around 40ish psi.
Is this to much for the cp3 to handle? What would happen if I ran that much? Blow the seals out of the pump or?
5,818
CP3 wont care but your FICM might. it may cause a lope unless you can turn the pressure down.
whats the volume on one of them? while pressure is one end to worry about, the volume to the pump is most important
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
12 psi is usually max you want to run. I wouldn't even waste my time messing with the pump off a 7.3 and iirc they run more like 60 psi.
Has anyone ever looked at a ficm? All the fuel does is cool it. Fuel pressure does not affect the ficm at all as it is just a straight shot right through the ficm, in one end and out the other. Your FPR is what freaks out with high pressure. Lbz+ trucks lope just as bad with high fuel pressure and they don't have ficms.
Dirtymaxx03
3,109
It does affect the FICM, and I personally know several people who run super high fuel pressure on their LBZ+ trucks
5,818
Trying to learn here, how does it affect the ficm when it doesn't physically monitor in coming fuel pressure?
dunno, you tell me. i ran 20psi to my FICM, i get a lope. bypass the fuel around the FICM and lope goes away. My truck is not the only this does this on as well. i dont think anyone has an exact reason as to why, like the posi-trac in the back of a dodge. nobody knows how it works, IT JUST DOES! :D
Operator1
477
NC
I remember seeing pictures where someone took their ficm apart, the part that the fuel goes through was just an aluminum heat sink IIRC. The fpr on the other hand, just needs its operating voltage adjusted to compensate for the increased fuel flow to stop the loping idle. I have ran as much as 25 psi, currently running 18.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I will stand corrected, but that voice in the back of my head won't let me understand it:confused::thumb:
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
That's what I'm saying, I had mine off and all I could see is that its just a tube that fuel flows through. No sensors or anything.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
All you want is positive pressure feeding the CP3 to get the benefit. It doesn't matter if it is 1psi as long as it stays there under WOT.
My Airdog 150 (older model) holds 11-12 at idle, and on the dyno at WOT it drops down to 2-3psi.
I would like to run a higher volume pump (gph), and keep the pressure low. The lift pump is there to supply the CP3 with fuel. Fuel does not compress(appreciably) so you do nothing trying to force more psi to the pump(except piss it off). You want to stay above 0psi so that you do not create a vacuum in the supply line and risk cavitation.
If you have rail pressure issues, increasing the CP3 supply from 5psi to 10psi isn't going to help you.
5,818
Ill say this, i cant say anyone has proved too much PSI is bad for a duramax besides the FICM deal. Is it un-necessary above a certain point, yes. Our concern is volume with pressure being the next in line. there are a couple guys on here that are or use to run mitsu pumps up to 45-50psi IIRC.
if the volume is there in the 7.3 pump and trubbs you really feel like makin it work, i dont see why not. your FICM may need bypassing but thats all i can think of.
Jackblack99
Oct 18, 2012
270
Nowhere
The lift pump im going to be running is 200gph at 8-9 psi. I know my little brother had his front seal on the cp3 blow out with an airdog 150. I think it had more to do with the fact he had welded his big return manifold banjo bolt welded shut and return fuel backed up and created pressure because it had no where to go.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
My Airdog You want to stay above 0psi so that you do not create a vacuum in the supply line and risk cavitation.
The single most important reason is the cp3 is lubricated via fuel, lack that and there is a 600 follar fuel leak
