How much crap....
9,903
149
........do you have just sitting around waiting to go on your truck? I was just thinking about all of the stuff I have that I haven't put on yet and it's really quite the list!!
deep pan for the trans
filter lock for deep pan filter for the trans
SoCal Diesel fuel pick up
3" boost pipe
EGR delete pipe
Federal Up-Pipe
Billet grille
LED interior lights
I had a Fuelab lift pump/filter/regulator but that is going onto Simon's race truck
And still coming are a set of HID's, an extra patch cord for the OBD2 port, grid heater, and hopefully a grid heater delete plate from MMLMM.
I need to get to work........
Sure wish I had a garage!!:(
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
a set of new michelins sitting in the garage - cant bring myself to pull the old ones off yet at 135,000 miles on them I might as well try to get 150,000.
a set of recon cab roof lights.
and i need get a new cb antenna and hide it somewhere. i did the shaved radio antenna and dont want any antennas showing
SmokeShow
6,818
Lawrenceburg, KY
Cognito Pitman & Idler Arm Braces
Water Pump (getting replaced along with bellhousing and rear engine cover at the moment)
New 4" exhaust replacing 5" system
Amsoil by-pass oil system
cabin air filters
CAT aux. fuel filter setup
Holley Blue fuel pump
SuperDiesel ported LB7 turbo inlet pipe
Undented front bumper
New (to me) shocks
I can't remember if there's something else or not...
wikdlmm
<-- OWFA
Jun 27, 2008
1,974
san angelo
cabin air filters
New (to me) shocks
How much u want for that 5" exhAust?
MadMooseEngineering
Mar 28, 2008
183
Boise, Idaho
cabin air filters
New (to me) shocks
The Holley Blue Pump might not be a good idea i had one on my truck and it went bad after a month plus its not a flow thru pump so when it goes truck wont run.
Im not try to bag on you i was just trying to help you from having to much trouble down the road.
SmokeShow
6,818
Lawrenceburg, KY
Sorry, it's not for sale. It's going for the project whenever I can do that.
Yeah, I'm not wild about the Holley Blue either but I got two and might as well put it on. I'm gonna put a bypass around it cause it won't be running all the time most likely. I'll probably put it on a Hobbs to come on at certain boost level or throttle %. Either that or a toggle switch in the cab somewhere. Chances are, you're right and I'll be buying something else down the road regardless but for now, it's already here and something is better than nothing. ;)
C-ya
Smokin LB7
Jul 25, 2008
191
New FPR
New (NON EGR ;) ) LB7 Heads
Grade-C Head Gaskets
ARP Head studs
Center Console
Powder Coated Engine Parts
Motor (With no built parts in it yet :( )
02bigstrokin
Sep 9, 2008
882
my transmission:rofl: oh wait, thats kind of a neccesity not a extra!
and maybe a 7 inch miter black stack
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
man i can't look at stuff like you guys can lol i gotta be putting it on. only thing i have not put on yet is my engine driven air compressor. simply because i'm still fabricating brackets lol. and i guess transynd and converter count but they will be going in as soon as the rest of my tranny parts arrive in the mail
Dozerboy
4,896
473
TX of course
Nothing for the truck need to get a lift pump soon though. I don't let parts sit very long. Well I do have a audio system that needs to go into my wife Tahoe, but she is ok with the Bose.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
This is what I have sitting here waiting to be installed lol.
Alum. Diff cover that I am building. Need to pull stock one to check final fit first.
Fog Light HIDs
CAT Filter setup
oil change
scangauge wired to see DSP5 setting
im sure theres more. I got a bunch of stuf sitting here for the mustnag though that needs to get done...
