Just wanting to see how much boost i should be seeing under normal driving and max with the PPE. Normal driving, under loads on a grade or good freeway pull i really dont see any boost unless important WOT. I can hear the turbo but the WatchDog monitor will say like 3-5lbs? Is this right? On a WOT pull i believe max was 19lb, i can't remember.
But by the sounds of the turbo when important under a lhad it sounds like its making more than it reading. I also put a brand new GM map sensor in when i done my HG's. Important wondering if this is in anyway related to my idle issue.
Another duramax pulled into the store beside me the other morning and you could hear a constant swoosh & whistle at idle were mine just sounds like a hug boat. No whistle or swoosh.
Any input?
Sent from my SCH-S720C using Tapatalk 2
Any input?
