It varies a little fom truck to truck, but you should be able to hold at least 21,000 on a hot tune. BTW welcome to the site.
OPPSS!!! Good answer for a DIFFERENT QUESTION!:
Normally if you are tuning on the street with stock CP3 truck, the peak power will occur when fuel demand (pulse width) pulls the rail down about 10% from commanded pressure. Usually about a 3100-3200 microsecond shot.
If your truck is an LLY or LB7 this means pulling it down from 23000PSI down to about 20500 roughly. 19500 to 21000 is where the peak power will usually be.
For LBZ's go down to about 23,000 PSI. My datalogging ain't working well on the LMM.
my max commanded pressure is 180 Mpa . I got a P0088 code while beating on it. My pressure must have spiked higher than 180 Mpa.
